Problem with Bootloader after OS update
What I suggest, do not use Software Updater as it changes extlinux files that handle kernel loading process.
Instead use below command.
Also mail contact@vicharak.in will update on that.
@Avi_Shihora
OK, but a normally a person would go with Software Updater.
Also Can Image Uploaded: https://downloads.vicharak.in/vicharak-axon/ubuntu/24_noble/V2.0.1_vicharak_axon_6.1_03072026-ubuntu-noble-24.04-raw.img.tar.gz
This is for ? sd and nvme or it can also be used on EMMC?
Correct, we will get solution of it, meanwhile you can use below image with update & upgrade command.
RAW image can be flashed in eMMC, SD card, USB and NVMe.
Flash Raw image using Windows
Flash Raw image using Linux
Hi @Avi_Shihora
I was able to flash image to SD and NVME.
On eMMC there is problem.
I was able to flash the image using dd cmd but it doesn’t boot(black screen and cursor).
Tried again with using usb cable and flashing(rktool) but tool rejected the image, so had to use old emmc image.
@Amit, Please Follow the documentation that I have already specifically mention on the above chat.
Hi @Avi_Shihora
I had followed the steps, might be issue with .img file i downloaded.
RKtools reported problem with the image.
On the other hand, BalenaEcther was able flash the eMMC using the latest image(separate download).
Also,
Ordered UART cable, will ran test with Ubuntu Software Updater once it is delivered.
There is no issue in (.img), as many users have already been using this image.
Could you show me what method do you proceed and make video on it !?
As I have clearly mentioned that this is RAW image, so method to flash image a little bit different, Kindly go through documentation.
How to flash raw image in eMMC ?
As I have seen you extlinux.conf file, it is changed when you update system with Ubuntu Software Updater, but still we can see the logs.
