Axon Power Tank
Hi team,
Building a system where I need power backup. So I was thinking to use following battery of ~12V.
But have confusion how to use with axon since it has usb c power supply slot.
I am new to building such stuff, please help here with product links if you can provide and architecture as. Well.
https://robu.in/product/pro-range-ifr-32650-lifepo4-6000mah-12-8v-4s1p-protected-battery-pack-3c-dc-jack-male-female/
Basically, system (robo) needs to be compact so looking for small possible solution for it.
Thanks and Regards,
Pradhuman
You’ll find 12V and GND pads below at the board near type-c port itself. Use it. Whatever battery pack that you choose they should support 12V output and also make sure you use the right polarity while soldering.
