Retro Pi Installation and Setup
Pre-requitsites
- Image : Ubuntu 24.04 LTS ( eMMC / RAW Image(SD Card / NVMe))
Overview
This guide explains how to:
- How to install RetroPi in Linux
- Add and configure a new controller in RetroPie.
- Add games (ROMs) for supported systems.
- Copy files into the correct RetroPie directories.
RetroPie works with EmulationStation as the frontend and supports multiple emulators.
Setup
Step 1: Update System Packages
Open a terminal and run:
Step 2: Install Required Dependencies
RetroPie needs several packages to build and run:
sudo apt install -y git dialog unzip xmlstarlet
sudo apt install libwayland-egl1=1.22.0-2.1build1
sudo apt install libwayland-cursor0=1.22.0-2.1build1
sudo apt install libwayland-server0=1.22.0-2.1build1
sudo apt install libwayland-client0=1.22.0-2.1build1
sudo apt install libxcb1=1.15-1ubuntu2
sudo apt install libwayland-dev
sudo apt install libxcb1-dev
Step 3: Clone the RetroPie Setup Script
git clone --depth=1 https://github.com/RetroPie/RetroPie-Setup.git
cd RetroPie-Setup
Step 4: Run the Setup Script
Launch the setup tool:
sudo ./retropie_setup.sh
Step 5 : Run emulator in terminal
emulationstation
The menu will appear with several options.
Adding a New Controller Key Setting
Method 1: Using EmulationStation
- Start RetroPie and wait until you reach the EmulationStation main screen.
- If no controller is detected, RetroPie will prompt:
No gamepad detected. Hold a button on your device to configure it. - Hold any button on the new controller until the setup wizard starts.
- Follow the prompts to map:
- D-Pad directions
- Start, Select
- A, B, X, Y buttons
- L1, R1, L2, R2
- Hotkey (usually Select)
The following table provides a complete mapping for all RetroPie controller inputs:
| RetroPie Input | Keyboard Key | Description |
| Up | W | D-pad up |
| Down | S | D-pad down |
| Left | A | D-pad left |
| Right | D | D-pad right |
| Start | Enter | Start / pause |
| Select | Right Shift | Select button |
| A | J | Primary action |
| B | K | Secondary action |
| X | U | Extra action |
| Y | I | Extra action |
| Left Shoulder (L1) | Q | Shoulder button |
| Right Shoulder (R1) | E | Shoulder button |
| Left Trigger (L2) | Z | Trigger button |
| Right Trigger (R2) | C | Trigger button |
| Left Thumb (L3) | 1 | Press-in left analog stick |
| Right Thumb (R3) | 2 | Press-in right analog stick |
| Left Analog Up | T | Analog stick up |
| Left Analog Down | G | Analog stick down |
| Left Analog Left | F | Analog stick left |
| Left Analog Right | H | Analog stick right |
| Right Analog Up | Up Arrow | Right analog up |
| Right Analog Down | Down Arrow | Right analog down |
| Right Analog Left | Left Arrow | Right analog left |
| Right Analog Right | Right Arrow | Right analog right |
| Hotkey Enable | Right Shift | Used for special commands (exit, save)|
- Press and hold any button to skip unwanted inputs.
Method 2: Reset and Add Again
If you want to reconfigure a controller:
rm ~/.emulationstation/es_input.cfg
emulationstation
This will erase all input settings and prompt you to reconfigure.
Adding Games (ROMs)
Reference : Transferring Roms - RetroPie Docs
Step 1: Download Games
Download Games for specific emulators supported by RetroPi. RetroPie supports many gaming systems. ROMs must be placed in the correct folder.
You can see the Directory named as
/home/vicharak/RetroPi/roms/
Example:
- NES ROMs →
/home/pi/RetroPie/roms/nes/ - SNES ROMs →
/home/pi/RetroPie/roms/snes/ - PlayStation ROMs →
/home/pi/RetroPie/roms/psx/
Step 2: Unzip the Downloaded Games and paste them into the specific ROMs Folder, as shown below.
Step 3: Restart EmulationStation
After copying ROMs:
emulationstation --restart
The new games should now appear in the menu.
Notes
- ROMs must be in supported formats (e.g.,
.nes,.sfc,.zipfor some systems).
References
- Official RetroPie Documentation: Debian/Ubuntu - RetroPie Docs
- Supported Systems List: Supported Systems - RetroPie Docs
If you have a query, Put it over here.
