Hi team,
My Axon board stopped booting and I believe the onboard eMMC has failed. Details below.
AXON v1.0 r0.4
Purchase : Sep 2026
Symptoms
- Power connected, red (power) + white + blue LEDs solid ON
- On a working Axon the white LED blinks — here it never blinks
- No SD card / NVMe was inserted, so it should boot from eMMC
What I tested (macOS, rkdeveloptool)
- Board enumerates in Maskrom:
Vid=0x2207, Pid=0x350b→ SoC and USB-OTG OK db rk3588_spl_loader_v1.15.113.bin→ succeeds (DDR init OK)- Your u-boot repo’s RK3588MINIALL.ini (v1.14.113) uses the same DDR v1.14 blobs and the same usbplug family, so it’s not a loader mismatch
rci→38 38 35 33 ...(RK3588, normal)rid→45 4D 4D 43 20("EMMC ")rfi→ Flash Size: 0 MB / 0 Sectorscs 1→ “Change Storage failed! Storage 1 is not available.”ppt→ “Not found any partition table!”rlat LBA 0, 16384, 1M, 8M, 30M, 60M → all return the identical 4 KB buffer, so reads never reach the eMMC- Repeated after a full cold power-off (30s) → same result
Conclusion
The SoC, DDR and USB are fine, but the eMMC is not detected by the loader at achip/solder or eMMC power-rail failure rather than a corrupted image.
Questions
- Is there an Axon-specific loader I should try before concluding it’s hardware?
- Are there any test points to check the eMMC supply rails (VCC/VCCQ)?
- If it is a hardware fault, what’s the RMA/repair process? Happy to share purchase details.
Thanks!
