Hi guys,
I received the board and was able to successfully boot it up and connect to my WiFi.
I performed updates using
I received the reboot prompt and rebooted. After this, the board is stuck in a boot loop.
Here is a video.
The board is connected to a wall socket with a regular charger capable of supplying upto 65W, so the charger isn’t a problem. I have also changed the power cable but the same problem happens.
Any thoughts?
Thank you
Does your adapter support 12V? it should be mentioned on the adapter itself.
@cycloneuav,
This issue shoule not be appeared as we have already resolved it.
What you can do, you can flash newer image from our server.
Hi @Avi_Shihora ,
Thank you for the update. I will try to reflash.
I want to use Ubuntu 22_jammy on my Axon as I need to install ROS2.
Is this specific issue fixed in Ubuntu 22_jammy ?
Yes, you can run on ROS2 in Ubuntu Jammy 22 Image. And, that Restart issue has been resolved on it as well.
https://downloads.vicharak.in/vicharak-axon/ubuntu/22_jammy/
An Alternative Option I would suggest is to use Docker ( Ubuntu 22 Jammy Image ) in Ubuntu 24.04 LTS Noble.
@cycloneuav let us know the status.
Hello. The new image worked. Thank you! The device seems smooth so far. I’m going to install standard ubuntu CLI only without the GUI / X because my operations are compute heavy. I don’t see a vicharak image without graphics / X on the downloads page. I’m assuming standard Ubuntu 22.04 will work fine…
I will keep everyone posted on my story.
