scrcpy (v3.3)
This application mirrors Android devices (video and audio) connected via USB or TCP/IP and allows control using the computer’s keyboard and mouse. It does not require root access or an app installed on the device. It works on Linux , Windows , and macOS .
I’m trying to compile the latest scrcpy from source on Ubuntu 24.10, but ran into a dependency resolution issue while installing required packages.
When I try to install libgbm-dev:
sudo apt install libgbm-dev
I get the following error:
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libgbm-dev : Depends: libgbm1 (= 24.2.8-1ubuntu1~24.04.1) but 24.2.8-1ubuntu1~24.10.1 is to be installed
E: Unable to correct problems, you have held broken packages.
also
sudo apt install ffmpeg libsdl2-2.0-0 adb wget gcc git pkg-config meson ninja-build libsdl2-dev libavcodec-dev libavdevice-dev libavformat-dev libavutil-dev libswresample-dev libusb-1.0-0 libusb-1.0-0-dev
ffmpeg is already the newest version (7:6.1.1-3ubuntu5).
libsdl2-2.0-0 is already the newest version (2.30.0+dfsg-1ubuntu3.1).
libsdl2-2.0-0 set to manually installed.
adb is already the newest version (1:34.0.4-1build3).
wget is already the newest version (1.21.4-1ubuntu4.1).
gcc is already the newest version (4:13.2.0-7ubuntu1).
git is already the newest version (1:2.43.0-1ubuntu7.2).
pkg-config is already the newest version (1.8.1-2build1).
meson is already the newest version (1.3.2-1ubuntu1).
ninja-build is already the newest version (1.11.1-2).
libavcodec-dev is already the newest version (7:6.1.1-3ubuntu5).
libavdevice-dev is already the newest version (7:6.1.1-3ubuntu5).
libavformat-dev is already the newest version (7:6.1.1-3ubuntu5).
libavutil-dev is already the newest version (7:6.1.1-3ubuntu5).
libswresample-dev is already the newest version (7:6.1.1-3ubuntu5).
libusb-1.0-0 is already the newest version (2:1.0.27-1).
libusb-1.0-0-dev is already the newest version (2:1.0.27-1).
libwayland-dev : Depends: libwayland-client0 (= 1.22.0-2.1build1) but 1.23.0-1 is to be installed
Depends: libwayland-server0 (= 1.22.0-2.1build1) but 1.23.0-1 is to be installed
Depends: libwayland-cursor0 (= 1.22.0-2.1build1) but 1.23.0-1 is to be installed
Depends: libwayland-egl1 (= 1.22.0-2.1build1) but 1.23.0-1 is to be installed
libxcb1-dev : Depends: libxcb1 (= 1.15-1ubuntu2) but 1.17.0-2 is to be installed
Seems like Ubuntu 24.10 is pulling newer versions of packages that don’t satisfy the strict version requirements of dev libraries from 24.04.
Anyone have a workaround that doesn’t involve downgrading or building every dep from source?
