Cant able to flash my axon
i downloaded the correct image from axon downloads, after extracting and trying to flash it says, loading firmware failed, help me to get this work
Kindly Follow Documentation properly.
You are flashing RAW image, so Kindly follow above Documentation.
Thanks, after following the steps from the video there is an 12th column in the video that is empty, but in my rk dev tool, only upto 11th column there is no 12th, in this case what to do ? i have attached the screenshots pls check
You can manually add 12th row and select image in column called Path.
Thank you much, and it working, after flashing it says, Download Image OK, so can i unplug from my pc ? and can i connect my monitor to check ? or tell me what to do ?
yes, you can unplug usb wire from your PC, and you can connect Monitor any HDMI port, wait for a while as it goes to first boot script, than Axon reboot automatically, and Ubuntu Mate screen will be shown on HDMI.
All working good, thanks a lot
now logged in, after that do i need to do anything ? can i do the software update ? pls suggest me
