Connect Axon with internet using ec200u-cn
Hi there
I tried every possible solution from internet but unable to use ec200u-cn to start internet in axon.
ec200u-cn is working as AT command from axon, but how to use it as internet dongle?
@padaliyajay20 , We also suggest to let Quectel know about this issue, as we have experienced with Quectel 520N-GL module as well and they guided us on module.
You can generate ticket in it as well.
https://e-service.quectel.com/en/support/home
  1. Send whole logs.
    dmesg > log.txt, when module is in device mdoe with enabled driver.
  2. Config file.
    zcat /proc/config.gz > config
  3. Kernel verison
    uname -a
Here is asked details
log.txt (126.0 KB)
config.txt (219.7 KB)
(.venv) vicharak@vicharak:~$ uname -a
Linux vicharak 6.1.75-axon #axon SMP Tue May  5 18:16:03 IST 2026 aarch64 aarch64 aarch64 GNU/Linux
also send output of mmcli -L and mmcli -m <number>
number is given by mmcli -L
I hope you have worked on linux before, they both are different commands.
Yes sorry, i did not read correctly
vicharak@vicharak:~$  mmcli -L
    /org/freedesktop/ModemManager1/Modem/0 [Quectel] EC200U
vicharak@vicharak:~$ mmcli -m 0
  General  |                 path: /org/freedesktop/ModemManager1/Modem/0
           |            device id: 7e3fa2e2a9e87cc1ba7cde71c01fd9e8de19ba0e
  Hardware |         manufacturer: Quectel
           |                model: EC200U
           |    firmware revision: EC200UCNAAR03A03M08
           |            supported: gsm-umts
           |              current: gsm-umts
           |         equipment id: 860617089596183
  System   |               device: /sys/devices/platform/usbdrd3_0/fc000000.usb/xhci-hcd.16.auto/usb5/5-1
           |              physdev: /sys/devices/platform/usbdrd3_0/fc000000.usb/xhci-hcd.16.auto/usb5/5-1
           |              drivers: option, rndis_host
           |               plugin: quectel
           |         primary port: ttyUSB5
           |                ports: enx024bb3b9ebe5 (net), ttyUSB0 (at), ttyUSB5 (at),
           |                       ttyUSB6 (at)
  Numbers  |                  own: 919664916673
  Status   |       unlock retries: sim-pin (3), sim-puk (10), sim-pin2 (3), sim-puk2 (10)
           |                state: registered
           |          power state: on
           |          access tech: lte
           |       signal quality: 100% (recent)
  Modes    |            supported: allowed: any; preferred: none
           |              current: allowed: any; preferred: none
  IP       |            supported: ipv4, ipv6, ipv4v6
  3GPP     |                 imei: 860617089596183
           |          operator id: 405857
           |        operator name: IND-JIO
           |         registration: home
           | packet service state: attached
  3GPP EPS | ue mode of operation: csps-2
  SIM      |     primary sim path: /org/freedesktop/ModemManager1/SIM/0
ip a command gives assigned ip on enx024bb3b9ebe5 !?
vicharak@vicharak:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host noprefixroute
2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether 4a:e7:24:bf:1b:ab brd ff:ff:ff:ff:ff:ff
3: end1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
    link/ether da:13:42:26:20:c3 brd ff:ff:ff:ff:ff:ff
4: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether 28:f5:2b:f2:20:19 brd ff:ff:ff:ff:ff:ff
    inet 192.168.1.15/24 brd 192.168.1.255 scope global dynamic noprefixroute wlan0
       valid_lft 84953sec preferred_lft 84953sec
    inet6 2401:4900:8fef:a188:f0dc:4829:6fe0:825e/64 scope global temporary dynamic
       valid_lft 86272sec preferred_lft 84801sec
    inet6 2401:4900:8fef:a188:da79:895e:136e:733a/64 scope global dynamic mngtmpaddr noprefixroute
       valid_lft 86272sec preferred_lft 86272sec
    inet6 fe80::d104:630a:9886:bae0/64 scope link noprefixroute
5: enx024bb3b9ebe5: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 1000
    link/ether 02:4b:b3:b9:eb:e5 brd ff:ff:ff:ff:ff:ff
    inet6 fe80::6255:ef08:8704:dc51/64 scope link noprefixroute
Make sure antenna is connected.
After reading output, I think now this is not right platform to ask, mostly some configuration is missing.
I highly recommend to ask Quectel about this one.
And also go though Quectel Forum as well.
Yes Antenna is connected already to quectel device.
So problem is from ec200u-cn internal configuration. not a issue from OS side?
Yes, without driver there would be no interface generated named as enx024bb3b9ebe5, so driver works.
Ok. i will contact them. thank you
Hi
Issue has been fixed. i also written gist for other who facing same issue with EC200U-CN
That’s nice. Hopefully this can also help others in community.
Closing this topic now.
