HOW TO ACCESS Serial Console
So I am trying to access the Serial Console with AXON Board , but unable to get the correct response .
What step I am missing
Here is my MiniCom config
Output
I am Connect as per the diagram
[2] RX ---- UART Tx
[4] TX ---- UART Rx
[6] GND - UART GROUND
Uart to usb images
Had the same problem and solved it using the right FTD cable.
The ones which are cheaper do not go well with higher baudrates.
By default AXON is configured for 1.5MBPS.
I ordered waveshare serial cable and it worked.
Sharing link of same just in case you are still figuring out this
USB-TTL-Cable
