How to setup pyaudio in Axon
- sudo pip install pipwin
- Add this line in
~/.bashrcfileexport PATH="$HOME/.local/bin:$PATH"and run commandsource ~/.bashrc - sudo apt-get install portaudio19-dev
- sudo pip install pyaudio
If you get an error like, then below python setup should be followed ![]()
error: externally-managed-environment
externally-managed-environment then the
× This environment is externally managed
╰─> To install Python packages system-wide, try apt install
python3-xyz, where xyz is the package you are trying to
install.
If you wish to install a non-Debian-packaged Python package,
create a virtual environment using python3 -m venv path/to/venv.
Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
sure you have python3-full installed.
If you wish to install a non-Debian packaged Python application,
it may be easiest to use pipx install xyz, which will manage a
virtual environment for you. Make sure you have pipx installed.
See /usr/share/doc/python3.12/README.venv for more information.
note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
The below command will create .vevn hidden folder for Python setup.
python -m venv .venv -
source /path/to/folder/.venv
e.g.
source ~/.venv/bin/activate -
You can see that you are in python environment.
(.venv) vicharak@vicharak:~/$ -
Now, Run below command :
pip install pipwinsudo apt-get install portaudio19-dev -
Install pyaudio using pip
pip install pyaudio
For Info, Click on the below link :
