Hi Team,
@Rajat-Pathak
i want to power AXON board via LFP battery 12.8v 60AH. Give me proper guidance to use battery with board.
There are two points in Axon reverse side. + and - 12V. You can use it to power externally.
my battery operating voltage is varies in between 11.5V and 14V.
You can only power Axon thru 12V, there’s no other way. You’ll need external circuitry to make this happen. Can use buck-boost converter to figure it out
