The port you are using MIPI_CSI0_RX, right !?
Overlays for other ports like, MIP_CSI1&2_RX and MIPI_CSI3&4_RX will available today
Yes I am using MIPI_CSI0_RX port currently
Do you have the adapter for the other two camera ports?
No currently i don’t have it , planning to get one , doe vicharak sells any connector for it
Any updates on support for gstreamer ?
sudo apt install gstreamer1.0-rockchip1
Below is a sample run on the ubuntu system
sudo gst-launch-1.0 filesrc location=sample-30s.mp4 ! parsebin ! mppvideodec ! fakesink
mpp[10270]: mpp_info: mpp version: c08762ebf author: Herman Chen 2026-08-11 docs: Update 1.1.0 CHANGELOG.md
mpp[10270]: mpp: unable to create enc vp8 for soc rk3576 unsupported
Setting pipeline to PAUSED …
Pipeline is PREROLLING …
Redistribute latency…
mpp[10270]: h264d_api: is_avcC=1
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
New clock: GstSystemClock
Got EOS from element “pipeline0”.
Execution ended after 0:00:02.383751839
Setting pipeline to NULL …
Freeing pipeline …
Also do not forget installing the gstreamer-base/good/bad plugins alongside.
thanks , will test it out
