Fenil
1
Hello Team,
We are testing the DEEPX DX-M1 Module with AXON hardware, connected over the M.2 PCI slot. Installed required packages
Steps:
We are getting error:
$ dxrt-cli --status
DXRT v2.6.3
[DXRT][Error] Device not found.
Successful detection, It should display:
$ dxrt-cli --status
DXRT v2.6.3
- Device 0: M1, Accelator type
--------------------- Version ---------------------
- RT Driver version : v1.3.1
- PCIe Driver version : v1.2.0
- FW version : v1.6.0
--------------------- Device Info ---------------------
- Memory : LPDDR5 5800 MHz, 3.92GiB
- Board : M.2, Rev 10.0
- PCIe : Gen3 X2 [01:00:00]
NPU 0: voltage 750 mV, clock 1000 MHz, temperature 35’C
NPU 1: voltage 750 mV, clock 1000 MHz, temperature 35’C
NPU 2: voltage 750 mV, clock 1000 MHz, temperature 35’C
dvfs Disabled
Thanks,
Fenil
Fenil
2
Further deepdive,
Installed the Kernel Module Driver, show the below status
vicharak@vicharak:~$ lsmod
Module Size Used by
rfcomm 49152 16
bnep 20480 2
dxrt_driver 45056 0
dx_dma 425984 1 dxrt_driver
vicharak@vicharak:~$ sudo systemctl status dxrt.service
Ă— dxrt.service - DX-RT Service
Loaded: loaded (/etc/systemd/system/dxrt.service; enabled; vendor preset: >
Active: failed (Result: exit-code) since Fri 2025-10-10 18:36:51 IST; 2min>
Main PID: 3312 (code=exited, status=1/FAILURE)
CPU: 10ms
Oct 10 18:36:51 vicharak systemd[1]: dxrt.service: Start request repeated too q>
Oct 10 18:36:51 vicharak systemd[1]: dxrt.service: Failed with result 'exit-cod>
Oct 10 18:36:51 vicharak systemd[1]: Failed to start DX-RT Service.
When We check the lspci command, also shown the entry like
0b:00.0 1200: 1ff4:0000
vicharak@vicharak:~$ lspci
00:00.0 PCI bridge: Rockchip Electronics Co., Ltd Device 3588 (rev 01)
01:00.0 Processing accelerators: Device 1ff4:0000 (rev 01)
Checking the dmesg log for DX
vicharak@vicharak:~/Fenil/DXNN/dx_rt_npu_linux_driver/modules$ dmesg | grep -i dx
[ 8.134320] dx_dma: loading out-of-tree module taints kernel.
[ 8.135176] dx_dma_pcie 0000:01:00.0: enabling device (0000 -> 0002)
[ 8.135491] dx_dma_pcie 0000:01:00.0: size of a BAR is not matched(8388608)
[ 8.135621] dx_dma_pcie: probe of 0000:01:00.0 failed with error -12
[ 8.138006] dxrt_driver_cdev_init: 0 devices
Thanks,
Fenil
Fenil
3
Tried with Full Installation packages from dx-all-suite, resolved all the errors.
What is the URL for “Full Installation packages from dx-all-suite”?
Do you have some tips about this?
