Basically, For that you required driver.
After that sudo reboot, in order to apply kernel into device.
Will Make guide for setting up 5G module.
Meanwhile you can explore using mmcli command.
Make sure Module is in USB mode,
You can be set it using below command.
Connect HAT To Axon and Attach Module in M.2 Connector.
Connect USB To Type-C Cable to Module to Axon USB and turn on Axon.
You can check usb devices are generated on tty like,
lsusb
sudo minicom -D /dev/ttyUSB2
Run below AT Commands.
AT+QCFG="data_interface",0,0
AT+QCFG="usbnet",1
Power off Axon.
Turn on Axon again and run mmcli -L.
Check on which device number module is detected, like
vicharak@vicharak:~$ mmcli -L
/org/freedesktop/ModemManager1/Modem/0 [Quectel] RM520N-GL
Check module applied is or not.
You cab check by running below command.
lsmod
Output can be liked below :
Module Size Used by
vicharak@vicharak:~$ lsmod
Module Size Used by
cdc_ether 24576 0
usbnet 40960 1 cdc_ether
option 65536 2
usb_wwan 24576 1 option
nfnetlink 20480 1
autofs4 45056 0
Check in more detailed.
mmcli -m 0
Output should be liked below :
vicharak@vicharak:~$ mmcli -m 0
General | path: /org/freedesktop/ModemManager1/Modem/0
| device id: 782621fa9a996a3c7fd80312ccfe2369c571b7dc
Hardware | manufacturer: Quectel
| model: RM520N-GL
| firmware revision: RM520NGLAAR03A03M4G
| carrier config: ROW_Commercial
| carrier config revision: XXXXXXXXX
| h/w revision: 20000
| supported: gsm-umts, lte, 5gnr
| current: gsm-umts, lte, 5gnr
| equipment id: XXXXXXXXXXXXX
System | device: /sys/devices/platform/fc880000.usb/usb3/3-1
| physdev: /sys/devices/platform/fc880000.usb/usb3/3-1
| drivers: option, qmi_wwan
| plugin: quectel
| primary port: cdc-wdm0
| ports: cdc-wdm0 (qmi), ttyUSB0 (ignored), ttyUSB1 (gps),
| ttyUSB2 (at), ttyUSB3 (at), wwan0 (net)
Status | lock: sim-pin2
| unlock retries: sim-pin (3), sim-puk (10), sim-pin2 (3), sim-puk2 (10)
| state: registered
| power state: on
| access tech: lte
| signal quality: 21% (recent)
Modes | supported: allowed: 3g; preferred: none
| allowed: 4g; preferred: none
| allowed: 3g, 4g; preferred: 4g
| allowed: 3g, 4g; preferred: 3g
| allowed: 5g; preferred: none
| allowed: 4g, 5g; preferred: 5g
| allowed: 4g, 5g; preferred: 4g
| allowed: 3g, 5g; preferred: 5g
| allowed: 3g, 5g; preferred: 3g
| allowed: 3g, 4g, 5g; preferred: 5g
| allowed: 3g, 4g, 5g; preferred: 4g
| allowed: 3g, 4g, 5g; preferred: 3g
| current: allowed: 4g; preferred: none
Bands | supported: utran-1, utran-4, utran-6, utran-5, utran-8, utran-2,
| eutran-1, eutran-2, eutran-3, eutran-4, eutran-5, eutran-7, eutran-8,
| eutran-12, eutran-13, eutran-14, eutran-17, eutran-18, eutran-19,
| eutran-20, eutran-25, eutran-26, eutran-28, eutran-29, eutran-30,
| eutran-32, eutran-34, eutran-38, eutran-39, eutran-40, eutran-41,
| eutran-42, eutran-43, eutran-46, eutran-48, eutran-66, eutran-71,
| utran-19, ngran-1, ngran-2, ngran-3, ngran-5, ngran-7, ngran-8,
| ngran-12, ngran-13, ngran-14, ngran-18, ngran-20, ngran-25, ngran-26,
| ngran-28, ngran-29, ngran-30, ngran-38, ngran-40, ngran-41, ngran-48,
| ngran-66, ngran-70, ngran-71, ngran-75, ngran-76, ngran-77, ngran-78,
| ngran-79
| current: utran-1, utran-4, utran-5, utran-8, utran-2, eutran-1,
| ngran-79
IP | supported: ipv4, ipv6, ipv4v6
3GPP | imei: XXXXXXXXXXXXXXX
| enabled locks: fixed-dialing
| operator id: XXXXX
| operator name: IND airtel
| registration: home
| packet service state: attached
3GPP EPS | ue mode of operation: csps-2
| initial bearer path: /org/freedesktop/ModemManager1/Bearer/0
| initial bearer ip type: ipv4v6
SIM | primary sim path: /org/freedesktop/ModemManager1/SIM/0
| sim slot paths: slot 1: /org/freedesktop/ModemManager1/SIM/0 (active)
| slot 2: none
