Issues seen with WPE (ubuntu-frame) kiosk
I’m migrating our kiosk from X11/Openbox + Chromium kiosk to Wayland (ubuntu-frame + wpe-webkit-mir-kiosk). Functionally it launches, but I’m hitting multiple issues that look like GPU acceleration is not being used.
Issues observed
  1. Software rendering (llvmpipe) instead of GPU
  • The renderer reports llvmpipe / software rasterizer, not Mali/Panfrost/RK GPU.
  • Because of this, the UI feels sluggish (scrolling, animations, page transitions).
  1. Lag / high CPU usage
  • CPU usage increases significantly when the web UI loads (even for normal screens).
  • The experience is not smooth compared to Chromium on X11.
  1. EGL/GL/GPU related errors in logs
  • ubuntu-frame logs show lines indicating fallback to software (mentions like EGL / GL renderer / llvmpipe).
  • WPE sometimes prints EGL initialization or GPU context warnings (looks like it can’t get a proper HW EGL context).
  1. Kiosk stability concerns (watchdog is okay, but rendering isn’t)
  • My URL-gate systemd timer successfully starts/stops WPE based on reachability,
  • but since rendering is software-based, it doesn’t meet performance requirements and may cause long-term thermal/CPU load issues.
Help I need from you guys
  • Confirm the correct GPU stack for our Vicharak image (RK3588) with ubuntu-frame/WPE.
  • Tell me the required drivers/packages, and whether snap needs additional interfaces (ex: opengl, access to /dev/dri or mali nodes).
  • Any required env vars / configuration to force GPU (and avoid llvmpipe).
  • If WPE is not the right option, recommend the best Wayland kiosk approach that uses GPU reliably on this board. the script
i am using now :
#!/usr/bin/env bash
set -euo pipefail
# CONFIG (edit if needed)
APP_URL="${APP_URL:-http://localhost:80/}"
# Optional: extra endpoints your frontend *must* be able to reach
# e.g. BACKEND_URLS="http://localhost:8084/health http://lcoalhost:8554/"
BACKEND_URLS="${BACKEND_URLS:-}"
WAIT_SECS="${WAIT_SECS:-180}"      # first-time wait before enabling watchdog
CHECK_SECS="${CHECK_SECS:-5}"      # watchdog interval
FRAME_BG="${FRAME_BG:-0x000000}"   # black
log(){ echo "[kiosk] $*"; }
if [[ $EUID -ne 0 ]]; then
  echo "Run as root: sudo $0"
  exit 1
fi
log "Install small deps"
apt-get update -y
apt-get install -y curl locales || true
locale-gen en_US.UTF-8 || true
update-locale LANG=en_US.UTF-8 LC_ALL=en_US.UTF-8 || true
log "Ensure snapd is running"
apt-get install -y snapd || true
systemctl enable --now snapd.socket || true
log "Install snaps"
snap install ubuntu-frame || true
snap install wpe-webkit-mir-kiosk || true
log "Configure ubuntu-frame (daemon + black wallpaper + hide cursor)"
snap set ubuntu-frame daemon=true || true
# ubuntu-frame accepts config items like wallpaper-top/bottom and cursor
snap set ubuntu-frame config="wallpaper-top=${FRAME_BG} wallpaper-bottom=${FRAME_BG} cursor=null" || true
log "Make sure WPE is connected to *ubuntu-frame* Wayland (NOT :wayland)"
snap disconnect wpe-webkit-mir-kiosk:wayland 2>/dev/null || true
snap connect wpe-webkit-mir-kiosk:wayland ubuntu-frame:wayland || true
log "Set WPE URL and keep it stopped until app is reachable"
snap set wpe-webkit-mir-kiosk url="$APP_URL" || true
snap set wpe-webkit-mir-kiosk daemon=false || true
snap stop wpe-webkit-mir-kiosk 2>/dev/null || true
log "Restart ubuntu-frame now (shows black background)"
snap restart ubuntu-frame || true
log "Create URL gate script (/usr/local/sbin/kiosk-url-gate.sh)"
cat >/usr/local/sbin/kiosk-url-gate.sh <<'EOF'
#!/usr/bin/env bash
set -euo pipefail
CURL_TIMEOUT="${CURL_TIMEOUT:-2}"
ok=1
check_one() {
  local url="$1"
  # Consider reachable if HTTP responds (2xx/3xx) quickly
  curl -fsS --max-time "$CURL_TIMEOUT" "$url" >/dev/null 2>&1
if ! check_one "$APP_URL"; then
  ok=0
else
  if [[ -n "$BACKEND_URLS" ]]; then
    for u in $BACKEND_URLS; do
      if ! check_one "$u"; then
        ok=0
        break
      fi
    done
  fi
fi
if [[ "$ok" -eq 1 ]]; then
  snap start ubuntu-frame 2>/dev/null || true
  snap start wpe-webkit-mir-kiosk 2>/dev/null || true
else
  # Keep ubuntu-frame running as a black "blank screen"
fi
EOF
chmod +x /usr/local/sbin/kiosk-url-gate.sh
log "Create systemd service + timer (watchdog every ${CHECK_SECS}s)"
cat >/etc/systemd/system/kiosk-url-gate.service <<EOF
[Unit]
Description=Start/stop WPE kiosk based on URL reachability
After=network-online.target snapd.service
Wants=network-online.target
[Service]
Type=oneshot
Environment=APP_URL=${APP_URL}
Environment=BACKEND_URLS=${BACKEND_URLS}
Environment=CURL_TIMEOUT=2
ExecStart=/usr/local/sbin/kiosk-url-gate.sh
EOF
cat >/etc/systemd/system/kiosk-url-gate.timer <<EOF
[Unit]
Description=Run kiosk URL gate periodically
[Timer]
OnBootSec=5
OnUnitActiveSec=${CHECK_SECS}
AccuracySec=1
[Install]
WantedBy=timers.target
EOF
systemctl daemon-reload
systemctl enable --now kiosk-url-gate.timer
log "Initial wait (up to ${WAIT_SECS}s) for first successful reachability..."
end=$(( $(date +%s) + WAIT_SECS ))
while [[ $(date +%s) -lt $end ]]; do
  if curl -fsS --max-time 2 "$APP_URL" >/dev/null 2>&1; then
    break
  fi
  sleep 1
done
log "Run the gate once now"
systemctl start kiosk-url-gate.service || true
log "Status"
snap services ubuntu-frame wpe-webkit-mir-kiosk || true
systemctl status kiosk-url-gate.timer --no-pager || true
journalctl -u kiosk-url-gate.service -n 20 --no-pager || true
log "Tip: Check renderer (llvmpipe = software rendering, will be laggy)"
snap logs -n 120 ubuntu-frame | grep -E "GL renderer|llvmpipe|EGL" || true
log "Done.".
setup i was using previously : Turning Axon board into a Server + Kiosk - #25 by pawarvarun
Is there any requirement to use Ubuntu 22 Jammy Version in your case ?
Which chromium version you are using ?
You can do many things in order to achieve this, are you running linux 6.1? or it is 5.10 only?
If you are running 6.1 then wayland should directly work out of the box, but for the chromium you may need some quirks to be set up.
Right now, chromium is built for x11 and internal video codec which is given by the rockchip itself.
If you want to set this up just for the kiosk environment then I would highly suggest you to use yocto builds, as it has good support of the wayland.
i am using this image : Link.
the installed linux version with this image is ig 6.1.
I was using chromium version 143.xx.
The reason i switched to this setup is : wayland (ubuntu-frame + wpe-webkit-mir-kiosk) is that 1. i was facing some lagging in graphics . 2.graphics get’s freezes after some time.
  1. Not specifically any ubuntu version that is light weight and can be used in production environment would be fine. i was using chromium 143.x.x. but in the other setup [ Wayland (ubuntu-frame + wpe-webkit-mir-kiosk)] how can i solve the issues observed. I would really appreciate if you guys can have urgent attention to this.
can i flash this updated gui image with windows rkdev tool ?
this is for linux tool,
rkdevtool db <rk3588_spl_loader>
rkdevtool wl 0 <image>
I have tried falshing udpated GUI image with rkdevtook with this method : Windows RKDevTool | Vicharak . but it’s not booting properly . showing vicharak logo . but then not showing screen nor any terminal. ia this Raw Image Ubuntu 24 Noble + Panfrost Support + Brave GPU Support image is flashable in emmc ?
hey! it’s raw image, which different from the emmc image that rkdev gui tool expect.
Yes, you can flash it in eMMC.
RAW image means it can be flashed in every storage media.
Flash RAW image in eMMC using Rkdev Tool in windows
this image didn’t work. i flashed it. i saw vicharak logo on boot then it initialized but didn;t show any screen after that. : Video . but it worked with my previous ubantu jammy 22.04. what could be the reason. i have tried multiple times. and followed same process for both the images. this worked . but the one you sent didn’t
try this then-
https://downloads.vicharak.in/vicharak-axon/beta-releases/V1.0_vicharak_axon_6.1_03072025-ubuntu-24.04-beta-emmc.tar.gz
After flshing RAW image, what was the behaviour of an LED?
https://docs.vicharak.in/vicharak_sbcs/axon/axon-getting-started/#verify-the-status-led
Follow these steps, which include erasing the eMMC and flashing it again
Steps to Follow
okay it worked. thanks. Can you provide an minimal image for this version as well ? similer to this ?https://downloads.vicharak.in/vicharak-axon/beta-releases/V1.0_vicharak_axon_5.10_26072025-ubuntu_22.04-jammy-minimal-beta-raw.tar.gz . but with the 6.1 version ?
Yes, this process may take 2–3 days, as it must pass through all necessary verification and validation steps.
As soon as it completes, will let you know in this thread.
Thanks, Will really appreciate that.
Working on it. Facing minor issue that leads to deliver a little bit delay.
Hi, thanks for the update.
Since this is blocking our work, could you please prioritize this and share the results as soon as possible? it would be really helpful.
Appreciate your support.
May I know why you need only Ubuntu 24 Noble Minimal Image !?
We only want Ubuntu 24.04 (Noble) minimal image because this device is meant to run only ubuntu-frame + WPE kiosk, without a full desktop environment.
The minimal image helps us keep the system lightweight, reduce background services, lower boot time and CPU/RAM usage, and avoid unnecessary desktop components that are not required for a kiosk setup. For your context we were using this image before : https://downloads.vicharak.in/vicharak-axon/beta-releases/V1.0_vicharak_axon_5.10_26072025-ubuntu_22.04-jammy-minimal-beta-raw.tar.gz . with a chromium browser kiosk setup to run a web application. and i configured it was doing software redering. that was causing delays like a very sluggish or slow UI. remaining points : points . i am happy if you provide any safe ubantu based image with these hardware supports.
