My AXON board spi1 and pwm 0_m1 on pin n0 20 is making conflict with each other
The problem is due to pin multiplexing (pinmux) on the RK3588. A physical pin can perform only one function at a time. Looking at your pinout:
Header Pin GPIO Available Functions
17 GPIO1_D0 UART6_TX / SPI1_MISO_M2 / I2C7
18 GPIO1_D1 UART6_RX / SPI1_MOSI_M2 / I2C7
19 GPIO1_D3 PWM1_M1 / UART4_RX / SPI1_CS0_M2
20 GPIO1_D2 PWM0_M1 / UART4_TX / SPI1_CLK_M2
You are currently using:
  • Pin 19 → PWM1_M1
  • Pin 20 → PWM0_M1
But SPI1 requires:
  • Pin 17 → MISO
  • Pin 18 → MOSI
  • Pin 19 → CS0
  • Pin 20 → CLK
So Pin 19 and Pin 20 cannot be PWM and SPI at the same time. The hardware cannot route both functions simultaneously. Kindly give me solution for this.
@Rajat-Pathak
So, Do you want to use one SPI and two PWM at the same time !?
yes, i want to use it at same time.
Do you want 2 PWMs? or only 1?
i am using two pwm outputs. PWM0_M0 and PWM0_M1 pin 13 and 20 on board
if your application only needs 1 PWM then there is a solution, otherwise you will need adapter of some kind
Can you assist me what kind of adapter needed for same.
are you using PWM for motor controller? then I will suggest motor controller based on I2C, UART or SPI
no i am using pwm for frquency generation.It can be only generated via pwm pins.
I think then we should be better to go with i2c to pwm converter IC / module,
You can go with PCA9685 16-Channel 12-bit PWM/Servo Driver I2C Compatible with Arduino PCA9685 16-Channel 12-bit PWM/Servo Driver I2C based for Arduino [RKI-2604] - ₹445.00 : Robokits India, Easy to use, Versatile Robotics & DIY kits or similar.
