Hi
I am using Raspberry Pi OV5647 5MP camera with axon through adaptor. but image is very dark. and very hard to see any moment if i do on front of camera.
How to fix this?
Hi
How to fix this?
Run below command :
sudo systemctl status rkaiq_3A.service
sudo systemctl restart rkaiq_3A.service
If it may required to install new package.
sudo apt install camera-engine-rkaiq
I ran last two commands and restarted service
○ rkaiq_3A.service - Enable Rockchip camera engine rkaiq
Loaded: loaded (/usr/lib/systemd/system/rkaiq_3A.service; enabled; preset: enabled)
Active: inactive (dead) since Wed 2026-07-29 11:19:21 IST; 5s ago
Duration: 130ms
Process: 6004 ExecStart=/etc/init.d/S40rkaiq_3A start (code=exited, status=0/SUCCESS)
Process: 6017 ExecStop=/etc/init.d/S40rkaiq_3A stop (code=exited, status=0/SUCCESS)
Main PID: 6007 (code=exited, status=0/SUCCESS)
CPU: 54ms
Jul 29 11:19:21 vicharak rkaiq_3A[6009]: ERR: Bad media topology for: /dev/media14
Jul 29 11:19:21 vicharak rkaiq_3A[6009]: ERR: Bad media topology for: /dev/media15
Jul 29 11:19:21 vicharak rkaiq_3A[6009]: XCORE:E:access /etc/iqfiles//ov5647_rpi-camera-v1_default.json && /etc/iqfiles//ov5647_rpi-camera-v1_default.bin failed!
Jul 29 11:19:21 vicharak rkaiq_3A[6009]: XCORE:E:_rkAiqManager init error!
Jul 29 11:19:21 vicharak rkaiq_3A[6009]: CAMHW:E:can't find sensor
Jul 29 11:19:21 vicharak rkaiq_3A[6009]: XCORE:E:camhw deinit error -7
Jul 29 11:19:21 vicharak rkaiq_3A[6009]: IPCSERVER:K:cid[-1] Deinit success
Jul 29 11:19:21 vicharak rkaiq_3A[6009]: MessageParser process loop exit!
Jul 29 11:19:21 vicharak rkaiq_3A[6009]: XCORE:K:cid[0] rk_aiq_uapi_sysctl_deinit_locked success.
Jul 29 11:19:21 vicharak S40rkaiq_3A[6018]: rkaiq_3A_server: no process found
vicharak@vicharak:~$ qv4l2
Gtk-Message: 11:21:01.826: Failed to load module "atk-bridge": 'gtk_module_display_init': /usr/lib/aarch64-linux-gnu/gtk-2.0/modules/libgail.so: undefined symbol: gtk_module_display_init
Using mplane plugin for capture
Make sure that you have enabled one overlay only of the particular connector you are using.
Yes. only one overlay is enabled
what could be issue?
Use CSI0 connector, and let us know.
looks like there is a issue with the camera ISP
If you are using latest image, then it should be directly work.
For the debugging purpose send us the output of
media-ctl -d 0 -p
media-ctl -d 1 -p
media-ctl -d 2 -p
Make sure you should have connected only a single camera before running these commands.
Ok i will try this weekend and let you know
I am using CSI0 now and here is output of commands you ask for
vicharak@vicharak:~$ media-ctl -d 0 -p
Media controller API version 6.1.75
Media device information
driver rkcif
model rkcif-mipi-lvds2
serial
bus info platform:rkcif-mipi-lvds2
hw revision 0x0
driver version 6.1.75
Device topology
- entity 1: stream_cif_mipi_id0 (1 pad, 11 links)
type Node subtype V4L flags 0
device node name /dev/video0
pad0: Sink
<- "rockchip-mipi-csi2":1 [ENABLED]
<- "rockchip-mipi-csi2":2 []
<- "rockchip-mipi-csi2":3 []
<- "rockchip-mipi-csi2":4 []
<- "rockchip-mipi-csi2":5 []
<- "rockchip-mipi-csi2":6 []
<- "rockchip-mipi-csi2":7 []
<- "rockchip-mipi-csi2":8 []
<- "rockchip-mipi-csi2":9 []
<- "rockchip-mipi-csi2":10 []
<- "rockchip-mipi-csi2":11 []
- entity 5: stream_cif_mipi_id1 (1 pad, 11 links)
device node name /dev/video1
pad0: Sink
<- "rockchip-mipi-csi2":1 []
<- "rockchip-mipi-csi2":2 [ENABLED]
- entity 9: stream_cif_mipi_id2 (1 pad, 11 links)
device node name /dev/video2
pad0: Sink
<- "rockchip-mipi-csi2":3 [ENABLED]
- entity 13: stream_cif_mipi_id3 (1 pad, 11 links)
device node name /dev/video3
pad0: Sink
<- "rockchip-mipi-csi2":4 [ENABLED]
- entity 17: rkcif_scale_ch0 (1 pad, 11 links)
device node name /dev/video4
pad0: Sink
<- "rockchip-mipi-csi2":5 [ENABLED]
- entity 21: rkcif_scale_ch1 (1 pad, 11 links)
device node name /dev/video5
pad0: Sink
<- "rockchip-mipi-csi2":6 [ENABLED]
- entity 25: rkcif_scale_ch2 (1 pad, 11 links)
device node name /dev/video6
pad0: Sink
<- "rockchip-mipi-csi2":7 [ENABLED]
- entity 29: rkcif_scale_ch3 (1 pad, 11 links)
device node name /dev/video7
pad0: Sink
<- "rockchip-mipi-csi2":8 [ENABLED]
- entity 33: rkcif_tools_id0 (1 pad, 11 links)
device node name /dev/video8
pad0: Sink
<- "rockchip-mipi-csi2":9 [ENABLED]
- entity 37: rkcif_tools_id1 (1 pad, 11 links)
device node name /dev/video9
pad0: Sink
<- "rockchip-mipi-csi2":10 [ENABLED]
- entity 41: rkcif_tools_id2 (1 pad, 11 links)
device node name /dev/video10
pad0: Sink
<- "rockchip-mipi-csi2":11 [ENABLED]
- entity 45: rockchip-mipi-csi2 (12 pads, 122 links, 0 routes)
type V4L2 subdev subtype Unknown flags 0
device node name /dev/v4l-subdev0
pad0: Sink
[stream:0 fmt:SGBRG10_1X10/2592x1944 field:none colorspace:raw
crop.bounds:(0,0)/2592x1944
crop:(0,0)/2592x1944]
<- "rockchip-csi2-dphy1":1 [ENABLED]
pad1: Source
-> "stream_cif_mipi_id0":0 [ENABLED]
-> "stream_cif_mipi_id1":0 []
-> "stream_cif_mipi_id2":0 []
-> "stream_cif_mipi_id3":0 []
-> "rkcif_scale_ch0":0 []
-> "rkcif_scale_ch1":0 []
-> "rkcif_scale_ch2":0 []
-> "rkcif_scale_ch3":0 []
-> "rkcif_tools_id0":0 []
-> "rkcif_tools_id1":0 []
-> "rkcif_tools_id2":0 []
pad2: Source
-> "stream_cif_mipi_id0":0 []
-> "stream_cif_mipi_id1":0 [ENABLED]
pad3: Source
-> "stream_cif_mipi_id2":0 [ENABLED]
pad4: Source
-> "stream_cif_mipi_id3":0 [ENABLED]
pad5: Source
-> "rkcif_scale_ch0":0 [ENABLED]
pad6: Source
-> "rkcif_scale_ch1":0 [ENABLED]
pad7: Source
-> "rkcif_scale_ch2":0 [ENABLED]
pad8: Source
-> "rkcif_scale_ch3":0 [ENABLED]
pad9: Source
-> "rkcif_tools_id0":0 [ENABLED]
pad10: Source
-> "rkcif_tools_id1":0 [ENABLED]
pad11: Source
-> "rkcif_tools_id2":0 [ENABLED]
- entity 58: rockchip-csi2-dphy1 (2 pads, 2 links, 0 routes)
device node name /dev/v4l-subdev1
pad0: Sink
[stream:0 fmt:SGBRG10_1X10/2592x1944@10000/150000 field:none colorspace:raw]
<- "m02_b_ov5647 1-0036":0 [ENABLED]
pad1: Source
-> "rockchip-mipi-csi2":0 [ENABLED]
- entity 63: m02_b_ov5647 1-0036 (1 pad, 1 link, 0 routes)
type V4L2 subdev subtype Sensor flags 0
device node name /dev/v4l-subdev2
pad0: Source
-> "rockchip-csi2-dphy1":0 [ENABLED]
vicharak@vicharak:~$ media-ctl -d 1 -p
driver rkisp0-vir2
model rkisp0
serial
bus info platform:rkisp0-vir2
hw revision 0x0
Device topology
- entity 1: rkisp-isp-subdev (4 pads, 10 links, 0 routes)
device node name /dev/v4l-subdev3
pad0: Sink
<- "rkisp_rawrd0_m":0 []
<- "rkisp_rawrd2_s":0 []
<- "rkisp_rawrd1_l":0 []
<- "rkcif-mipi-lvds2":0 [ENABLED]
pad1: Sink
<- "rkisp-input-params":0 [ENABLED]
pad2: Source
[stream:0 fmt:YUYV8_2X8/2592x1944 field:none colorspace:smpte170m quantization:full-range
-> "rkisp_mainpath":0 [ENABLED]
-> "rkisp_selfpath":0 [ENABLED]
-> "rkisp_fbcpath":0 [ENABLED]
-> "rkisp_iqtool":0 [ENABLED]
pad3: Source
-> "rkisp-statistics":0 [ENABLED]
- entity 6: rkisp_mainpath (1 pad, 1 link)
device node name /dev/video11
pad0: Sink
<- "rkisp-isp-subdev":2 [ENABLED]
- entity 12: rkisp_selfpath (1 pad, 1 link)
device node name /dev/video12
pad0: Sink
- entity 18: rkisp_fbcpath (1 pad, 1 link)
device node name /dev/video13
pad0: Sink
- entity 24: rkisp_iqtool (1 pad, 1 link)
device node name /dev/video14
pad0: Sink
- entity 30: rkisp_rawrd0_m (1 pad, 1 link)
device node name /dev/video15
pad0: Source
-> "rkisp-isp-subdev":0 []
- entity 36: rkisp_rawrd2_s (1 pad, 1 link)
device node name /dev/video16
pad0: Source
- entity 42: rkisp_rawrd1_l (1 pad, 1 link)
device node name /dev/video17
pad0: Source
- entity 48: rkisp-statistics (1 pad, 1 link)
device node name /dev/video18
pad0: Sink
<- "rkisp-isp-subdev":3 [ENABLED]
- entity 54: rkisp-input-params (1 pad, 1 link)
device node name /dev/video19
pad0: Source
-> "rkisp-isp-subdev":1 [ENABLED]
- entity 60: rkcif-mipi-lvds2 (1 pad, 1 link, 0 routes)
device node name /dev/v4l-subdev4
pad0: Source
-> "rkisp-isp-subdev":0 [ENABLED]
vicharak@vicharak:~$ media-ctl -d 2 -p
Failed to enumerate /dev/media2 (-2)
try installing camera-engine-rkaiq package,
Then reboot your system and check if it is still green or not
