Board: Vicharak Axon (RK3588), single Ethernet port
Interface: end1 (no end0)
OS / kernel: <add uname -a output>
Image:
Summary
The LAN port shows a valid link, but no packets pass. The board has no other network path.
carrier=1- Speed 1000 Mb/s, full duplex
- Port LEDs blink
TX packetsincreasesRX packetsstays 0- No IPv4 address. DHCP gets no lease.
- Only an IPv6 link-local address:
fe80::.../64
Tests
- Two different Ethernet cables.
- Two different peers: a Mac and a site router.
- Static IPv4 on three subnets:
192.168.77.2/24192.168.2.10/24192.168.29.240/24
- Ping to each gateway fails with
Destination Host Unreachable. - Peer counters:
Ipkts 0,Opkts > 1700. - No ARP reply from the board.
ip -br linkshows onlyend1.
Reproduction
cat /sys/class/net/end1/carrier
cat /sys/class/net/end1/operstate
ethtool end1
ip -br link
ip -4 addr show end1
dmesg | grep -iE "end1|stmmac|phy|link is"
Question
- Is this a known PHY or magnetics fault on the Axon?
- Does the board need an RMA?
- Which additional tests do you recommend?
The port worked until 2026-10-18. The board then went offline and has not passed traffic since.
