Hi i am keerthan, i got the new shrikeFI (8MB PSRAM and BMS variant). I want to add the board support for shrikeFI in platform.io for this i will need the complete spec of this board mainly the PSRAM configs which will cause a lot of issues in the future.
So i have started debugging it first with blink sketch then with the checking the size of flash and the PSRAM, which is where i have come across with the issue, i have attched a check.txt file which contains the code i used to check the the board and here are my tool config and serial and compiled logs
serialLOGS.txt (305 Bytes)
check.txt (871 Bytes)
compileLOGS.txt (2.9 KB)
