I have sent a mail on above mail id.
#!/usr/bin/env python3
import os
import time
PWM0 = "/sys/class/pwm/pwmchip0/pwm0"
PWM1 = "/sys/class/pwm/pwmchip1/pwm0"
PWM0_EXPORT = "/sys/class/pwm/pwmchip0/export"
PWM1_EXPORT = "/sys/class/pwm/pwmchip1/export"
DELAY = 2 # Seconds between frequency changes
DUTY_PERCENT = 50 # Duty cycle
def write(path, value):
with open(path, "w") as f:
f.write(str(value))
def read(path):
with open(path, "r") as f:
return f.read().strip()
def export_pwm(export_file, pwm_path):
if os.path.exists(pwm_path):
print(f"{pwm_path} already exported.")
return
print(f"Exporting {pwm_path}...")
write(export_file, 0)
time.sleep(0.2)
def disable_pwm(path):
try:
write(f"{path}/enable", 0)
time.sleep(0.02)
except Exception as e:
print(f"Disable failed for {path}: {e}")
def safe_zero_duty(path):
try:
write(f"{path}/duty_cycle", 0)
except Exception:
pass
def set_pwm(path, frequency):
period = int(1_000_000_000 / frequency)
duty = int(period * DUTY_PERCENT / 100)
print("--------------------------------------------")
print(f"Configuring {path}")
print(f"Frequency : {frequency} Hz")
print(f"Period : {period} ns")
print(f"Duty : {duty} ns")
# Step 1: disable output before reconfiguring
disable_pwm(path)
try:
# Step 3: set new period (safe now that duty_cycle == 0)
write(f"{path}/period", period)
# Step 4: set real duty cycle
write(f"{path}/duty_cycle", duty)
print("Kernel reports:")
print("Period =", read(f"{path}/period"))
print("Duty =", read(f"{path}/duty_cycle"))
# Step 5: enable
write(f"{path}/enable", 1)
print("PWM Enabled =", read(f"{path}/enable"))
print(f"ERROR configuring {path}")
print(e)
# Try to leave the channel disabled rather than half-configured
try:
except Exception:
pass
def cleanup():
print("\nDisabling PWMs...")
for pwm in [PWM0, PWM1]:
try:
write(f"{pwm}/enable", 0)
except Exception:
pass
print("Done.")
def main():
export_pwm(PWM0_EXPORT, PWM0)
export_pwm(PWM1_EXPORT, PWM1)
print("\nStarting Dual PWM Test")
print("======================")
# PWM0 frequencies
pwm0_freqs = [10000, 11000, 12000, 13000, 14000]
# PWM1 frequencies
pwm1_freqs = [16000, 17000, 18000, 19000, 20000]
try:
for f0, f1 in zip(pwm0_freqs, pwm1_freqs):
print("\n============================================")
print(f"PWM0 -> {f0} Hz")
print(f"PWM1 -> {f1} Hz")
set_pwm(PWM0, f0)
set_pwm(PWM1, f1)
print(f"\nRunning for {DELAY} seconds...")
time.sleep(DELAY)
except KeyboardInterrupt:
print("\nInterrupted by user.")
finally:
cleanup()
if __name__ == "__main__":
main()
As it is solved, going to closed this issue.
