Regarding the Speaker for Axon
Hi team,
Can you pls confirm if this speaker is ok to use directly on axon board?
https://techiesms.com/product/tr-ws-2014b-ultra-thin-cavity-speaker/
We have tested speaker with 4 ohm impedance. Let me share the link with you if i can find somewhere
@Akshar sure, thanks for quick reply.
I would appreciate if you also provide the recommended microphone product link as well.
https://m.indiamart.com/proddetail/4-ohm-2-watt-speaker-35mm-diameter-external-magnet-speaker-2853688479662.html?srsltid=AfmBOorNsLN66p3B6LpZymt_ikqxQH_Fho1bQNfIzKAt0O-19emzjEEC
This is quick link i can find now, you can connect with them meanwhile i’ll share you another examples soon.
Okay, but if we use 7ohm speaker, will it impact negatively on the board?
It should work in theory but sound will not be that great.
Okay, can you pls also help to provide microphone link to plug in MIC_In slot?
@Akshar
@Akshar I found this mic, Https://www.digikey.in/en/products/detail/same-sky-formerly-cui-devices-/CMEJ-0629-36-L050/10253453?gclsrc=aw.ds&gad_source=1&gad_campaignid=23301206764&gbraid=0AAAAADrbLlg31xPbmzlMqFL4w1p3T_8vi&gclid=Cj0KCQjwm6POBhCrARIsAIG58CIMkIwmDJ7xRmQzyvf81lwEDczi87PKLqtH-2rf_kiGpylVg7W_me0aAhDIEALw_wcB
Is it ok to be used?
yes this will work, you can try.
