Requesting a reference pipeline and benchmark metrics from Vicharak to compare against our current Axon setup and identify further performance optimization opportunities
Good Evening all,
We would like to seek your guidance on further optimizing our pipelines running on the Vicharak Axon. It would be helpful if you could share a reference pipeline or benchmark configuration that has already been tested and optimized on the Axon. This would allow us to compare our current implementation against a known baseline and identify areas where further optimization is possible.
Currently, our setup consists of 4 simultaneous substreams at a resolution of 1080x720, running 4 unique models and 1 pose model. The device has an 8-core CPU and 7.7 GB of available RAM, with a target of 15 FPS per stream.
During our testing, we are observing approximately 10–15 FPS per stream when the device temperature is below 70°C. Above 70°C, the performance generally drops to 7–10 FPS, with occasional drops to 4–5 FPS. CPU utilization is typically around 50–70%, increasing to 80–90% under higher workloads, while RAM consumption is around 4.5–5.5 GB. NPU utilization varies across the three cores depending on the workload.
If you could share a reference implementation along with its corresponding FPS and resource utilization metrics (CPU, RAM and NPU), it would help us evaluate our current performance and understand the scope for further optimization.
Greetings of the day, @DwarfEYe ,
Please refer to the examples found in this repository.
