How to enable RTC clock on AXON?
I can see a battery connector for RTC clock on the board. Upon some investigation I found that rtc clock is enabled by Hymn8563. And /dev/rtc0 is wired to this Hymm8563. However, I can’t find any external RTC clock IC on the board. Is this result of a bad merge in kernel device tree?
