Hey Guys
I am trying to run docker on the image which was installed with Axon but I found that kernel installed is missing CONFIG_IP_NF_RAW $ zgrep IP_NF_RAW /proc/config.gz
CONFIG_IP_NF_RAW is not set
I can try building the kernel myself but just wanted to check if you have suggestion to fix it without building the kernel
This is the actual error I get when running docker compose:
Error response from daemon: failed to set up container networking: driver failed programming external connectivity on endpoint frigate (a57f39a9fb52d5be0fb7017e6bddc9fbadf1d56fea7cb50d36420c72bce7e02a): Unable to enable DIRECT ACCESS FILTERING - DROP rule: (iptables failed: iptables --wait -t raw -A PREROUTING -p tcp -d 172.18.0.2 --dport 8554 ! -i br-2beec5707418 -j DROP: iptables v1.8.7 (legacy): can't initialize iptables table `raw': Table does not exist (do you need to insmod?)
Perhaps iptables or your kernel needs to be upgraded.
Yes I installed from the server as per your suggestion. I am using 22.04 LTS release fyi.
I have seleteted correct iptables:
vicharak@vicharak:~/frigate$ sudo update-alternatives --config iptables
There are 2 choices for the alternative iptables (providing /usr/sbin/iptables).
Selection Path Priority Status
0 /usr/sbin/iptables-nft 20 auto mode
* 1 /usr/sbin/iptables-legacy 10 manual mode
2 /usr/sbin/iptables-nft 20 manual mode
I am trying to run Installation | Frigate using docker compose. It still throw the following error:
vicharak@vicharak:~/frigate$ docker compose up -d
WARN[0000] /home/vicharak/frigate/docker-compose.yml: the attribute `version` is obsolete, it will be ignored, please remove it to avoid potential confusion
[+] Running 0/1
β ΄ Container frigate Starting 0.5s
Error response from daemon: failed to set up container networking: driver failed programming external connectivity on endpoint frigate (ddad2362a1de4a269c0932d1a0b2691b53c9a9d6b4d7d5e3f3180248c116835d): Unable to enable DIRECT ACCESS FILTERING - DROP rule: (iptables failed: iptables --wait -t raw -A PREROUTING -p tcp -d 172.18.0.2 --dport 8554 ! -i br-2beec5707418 -j DROP: iptables v1.8.7 (legacy): can't initialize iptables table `raw': Table does not exist (do you need to insmod?)
(exit status 3))
Does your kernel is build with config_ip_raw? Can you help me point to correct kernel config too, I will see if I can build the kernel myself,
We have updated the kernel support. You can get the new kernel packages from the vicharak apt server.
Check the updated packages, upgrade, and try Frigate with the updated kernel.
We will provide a kernel build guide soon. If you need any other help, let us know!
Hi, I am also unable to run docker on Axon.
OS: Ubuntu Noble
Kernel version:
Linux vicharak 6.1.75-axon #axon SMP Mon Apr 28 16:49:13 IST 2025 aarch64 aarch64 aarch64 GNU/Linux
I have followed the above steps. The error I am getting after running:
$ sudo docker run hello-world
$ docker: Error response from daemon: failed to set up container networking: failed to create endpoint kind_goldstine on network bridge: failed to add the host (veth14c8741) <=> sandbox (vethca050ec) pair interfaces: operation not supported
$ ip - a
$ 4: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
link/ether 1e:45:82:bd:fd:d1 brd ff:ff:ff:ff:ff:ff
inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
valid_lft forever preferred_lft forever
sudo docker network list shows all three bridge, host and none.
