Hello Vicharak Team,
I’ve been trying to establish an SPI-based master-slave communication between the Axon board (Master) and an ESP32-S3 (Slave). While doing so, I’ve faced the following issues that I’d appreciate some help with.
1. SPI Interface Setup (spidev issues)
I was following the standard procedure to enable spidev on Axon (running the custom Linux image). I made the necessary changes including:
Overlays for SPI (
spidev2.dtbo) -
Updating U-Boot using:
sudo u-boot-update -k Image-6.1.75-axon -r initrd.img-6.1.75-axon -d rk3588-axon-linux-6.1.75-axon.dtb -o spidev2.dtbo
Despite that, the SPI device /dev/spidev* was not appearing. I attempted to manually load the device:
echo spidev | sudo tee /sys/class/spi_master/spi2/device/modalias
But received:
tee: /sys/class/spi_master/spi2/device/modalias: Permission denied
Also, modprobe spidev didn’t help even though the spidev.ko module was available. This suggests a permission or overlay-related issue. I also confirmed configfs is already mounted:
sudo mount -t configfs none /sys/kernel/config
mount: /sys/kernel/config: none already mounted or mount point busy.
2. Post-reboot Wi-Fi Module Disappearance
After making the SPI-related changes and executing:
The Wi-Fi module stopped working. On reboot, the system could no longer detect any wireless interfaces. lshw was not available initially, and installing it failed due to permission errors:
E: Could not open lock file /var/lib/dpkg/lock-frontend - open (13: Permission denied)
Attempting to reinstall or check firmware also didn’t help:
sudo apt download firmware-misc-nonfree
But it resulted in:
E: Unable to locate package firmware-misc-nonfree
No wireless interfaces listed
Running:
iwconfig
gave:
lo no wireless extensions.
eth0 no wireless extensions.
Log Snippets for Reference
SPI Overlay Attempt:
P: Checking for EXTLINUX directory... found.
P: Writing config for Image-6.1.75-axon...
P: Updating /boot
After sudo reboot — Wi-Fi Gone:
No Wi-Fi module/interface visible via `iwconfig` or `ip a`
Failed lshw install:
bash: lshw: command not found
sudo apt install lshw
My Environment:
- Axon board with Linux kernel
6.1.75-axon - ESP32-S3 connected via SPI (slave)
- Working on SPI Master-Slave protocol for stepper motor control
- SSH and serial access available
- Wi-Fi previously functional before SPI config and reboot
What I Need Help With:
- Why isn’t
spidevgetting properly registered even after overlay updates? - What could cause the Wi-Fi module to disappear after SPI overlay changes and reboot?
- How can I safely restore wireless connectivity without reflashing the whole image?
- Any suggestion for debugging or resetting the network interface?
Let me know if you need any more logs or output. I really appreciate your time and help.
Thanks,
Himani Netha.
