Hi, is it possible to test the rockchip GPIO’s from Linux? Do you have a reference code or something for it?
To Configure GPIO Pins
To configure you need root permission.
Run su command in teminal and enter root password.
Vicharak Board Root password is root
Here, you can find SOC GPIOs Header pins for Vaaman RK3399 Processor.
Vaaman GPIO Description | Vicharak -
The GPIOs are typically accessible in
/sys/class/gpiofolder.
Each GPIO Pins have folder named asgpio<GPIO_NUMBER>.
Example : GPIO PIN 40 => gpio135 for GPIO4_A7You need root permission to configure it, Make sure you’re in root User.
by running commandsudo suthen, enter the root password OR you can run below commands usingsudo.If the folder is not present, the GPIO needs to be exported first.
echo 135 > /sys/class/gpio/exportSimilarly, you can also unexport it -
echo 135 > /sys/class/gpio/unexport -
To read the value of GPIO number 135, need to first set the gpio as an output
echo out > /sys/class/gpio/gpio135/directionSimilarly, you can set gpio as an input
echo in > /sys/class/gpio/gpio135/direction -
Read the value by
cat /sys/class/gpio/gpio135/value
To set GPIO4_D5 as low
echo 0 > /sys/class/gpio/gpio135/value -
To set GPIO4_D5 as high
echo 1 > /sys/class/gpio/gpio135/value
Or in simpler way, you can do this way,
sudo apt install libgpiod-dev
sudo gpioset gpiochipX <gpio_num>=value
sudo gpioget gpiochipX <gpio_num>
You can get more info by,
sudo gpioinfo
Hi, I tried using ‘sudo gpioinfo’ but I could see gpiochip0 to gpio4. Which one do I use?
I want to try using one of these:
Is this not the right pinmap?
You right both of them are same only!
Let’s assume you want to make GPIO4_D2 high, then
sudo gpioset gpiochip4 26=1 # 1 for making it high
Here, 26 number is calculated as follows,
A0-A7 → 0-7
B0-B7 → 8-15
C0-C7 → 16-23
D0-D7 → 24-31
Same for the making it low,
sudo gpioset gpiochip4 26=0 # 0 for making it low
