Unable to configure network firewall (UFW)
Hello,
Is anyone able to get ufw running?
I get error stating missing kernel-modules
$ sudo /usr/share/ufw/check-requirements
Has python: pass (binary: python3, version: 3.10.12, py3)
Has iptables: pass
Has ip6tables: pass
Has /proc/net/dev: pass
Has /proc/net/if_inet6: pass
This script will now attempt to create various rules using the iptables
and ip6tables commands. This may result in module autoloading (eg, for
IPv6).
Proceed with checks (Y/n)? Y
== IPv4 ==
Creating 'ufw-check-requirements'... done
Inserting RETURN at top of 'ufw-check-requirements'... iptables v1.8.7 (nf_tables):  RULE_INSERT failed (No such file or directory): rule in chain ufw-check-requirements
ERROR: could insert RETURN rule into 'ufw-check-requirements'. Aborting
WARN: detected other firewall applications:
 firewalld
(if enabled, these applications may interfere with ufw)
FAIL: check your kernel and that you have iptables >= 1.4.0
Can you tell us in which kernel you are getting this errors?
Sure, here is the output of uname
$ uname -a
Linux haedus 5.10.230-axon axon SMP Mon Jan 6 12:31:30 IST 2025 aarch64 aarch64 aarch64 GNU/Linux
Try doing
sudo apt update && sudo apt upgrade
We have updated the kernel modules with netfilter support.
Hi, thanks for providing the upgrades.
I think some modules are still missing even with latest upgrades.
Here’s the output now:
Has iptables: pass
Has ip6tables: pass
IPv6).
== IPv4 ==
Inserting RETURN at top of 'ufw-check-requirements'... done
TCP: pass
UDP: pass
destination port: pass
source port: pass
ACCEPT: pass
DROP: pass
REJECT: FAIL
error was: iptables v1.8.7 (legacy): Couldn't load target `REJECT':No such file or directory
Try `iptables -h' or 'iptables --help' for more information.
LOG: FAIL
error was: iptables v1.8.7 (legacy): Couldn't load target `LOG':No such file or directory
hashlimit: FAIL
error was: iptables v1.8.7 (legacy): Couldn't load match `hashlimit':No such file or directory
limit: FAIL
error was: iptables v1.8.7 (legacy): Couldn't load match `limit':No such file or directory
ctstate (NEW): pass
ctstate (RELATED): pass
ctstate (ESTABLISHED): pass
ctstate (INVALID): pass
ctstate (new, recent set): FAIL (no runtime support)
error was: iptables v1.8.7 (legacy): Couldn't load match `recent':No such file or directory
ctstate (new, recent update): FAIL (no runtime support)
ctstate (new, limit): FAIL
interface (input): pass
interface (output): pass
multiport: FAIL
error was: iptables v1.8.7 (legacy): Couldn't load match `multiport':No such file or directory
comment: FAIL
error was: iptables v1.8.7 (legacy): Couldn't load match `comment':No such file or directory
addrtype (LOCAL): pass
addrtype (MULTICAST): pass
addrtype (BROADCAST): pass
icmp (destination-unreachable): pass
icmp (source-quench): pass
icmp (time-exceeded): pass
icmp (parameter-problem): pass
icmp (echo-request): pass
== IPv6 ==
Creating 'ufw-check-requirements6'... done
Inserting RETURN at top of 'ufw-check-requirements6'... done
TCP: pass
UDP: pass
source port: pass
ACCEPT: pass
DROP: pass
REJECT: FAIL
error was: ip6tables v1.8.7 (nf_tables): Chain 'REJECT' does not exist
Try `ip6tables -h' or 'ip6tables --help' for more information.
LOG: FAIL
error was: ip6tables v1.8.7 (nf_tables): Chain 'LOG' does not exist
hashlimit: FAIL
error was: ip6tables v1.8.7 (nf_tables): Couldn't load match `hashlimit':No such file or directory
limit: FAIL
error was: ip6tables v1.8.7 (nf_tables): Couldn't load match `limit':No such file or directory
ctstate (NEW): pass
error was: ip6tables v1.8.7 (nf_tables): Couldn't load match `recent':No such file or directory
multiport: FAIL
error was: ip6tables v1.8.7 (nf_tables): Couldn't load match `multiport':No such file or directory
comment: FAIL
error was: ip6tables v1.8.7 (nf_tables): Couldn't load match `comment':No such file or directory
icmpv6 (destination-unreachable): FAIL
error was: ip6tables v1.8.7 (nf_tables): unknown option "--icmpv6-type"
icmpv6 (packet-too-big): FAIL
icmpv6 (time-exceeded): FAIL
icmpv6 (parameter-problem): FAIL
icmpv6 (echo-request): FAIL
icmpv6 with hl (neighbor-solicitation): FAIL
icmpv6 with hl (neighbor-advertisement): FAIL
icmpv6 with hl (router-solicitation): FAIL
icmpv6 with hl (router-advertisement): FAIL
ipv6 rt: FAIL
error was: ip6tables v1.8.7 (nf_tables): Couldn't load match `rt':No such file or directory
FAIL: check your kernel and iptables for additional runtime support
I used a iptables legacy, even then it throws an error:
Has iptables: pass
Has ip6tables: pass
IPv6).
== IPv4 ==
TCP: pass
UDP: pass
source port: pass
ACCEPT: pass
DROP: pass
REJECT: FAIL
LOG: FAIL
hashlimit: FAIL
limit: FAIL
ctstate (NEW): pass
multiport: FAIL
comment: FAIL
== IPv6 ==
Creating 'ufw-check-requirements6'... modprobe: FATAL: Module ip6_tables not found in directory /lib/modules/5.10.230-axon
ip6tables v1.8.7 (legacy): can't initialize ip6tables table `filter': Table does not exist (do you need to insmod?)
Perhaps ip6tables or your kernel needs to be upgraded.
ERROR: could not create 'ufw-check-requirements6'. Aborting
We have again updated the kernel packages, you can do this way
sudo apt reinstall linux-image-5.10.230-axon linux-headers-5.10.230-axon
I think that fixes it, thank you!
I am trying to install tun/tap interface, and the kernel seems to be missing iproute, can you please build and publish a new update again?
@djkabutar
Additionally, can you guide me how did you fix it? Which modules did you compile into the kernel?
Okay we will do. And update you.
Hello everyone,
sorry its almost a year and I think still some important kernel modules are missing in the axon kernel (v 6.1.75)
$ sudo modprobe tun
modprobe: FATAL: Module tun not found in directory /lib/modules/6.1.75-axon
Because of this, I’m unable to run any tunnel services on vicharak like tailscale .
$ sudo systemctl status  --full tailscaled
● tailscaled.service - Tailscale node agent
     Loaded: loaded (/lib/systemd/system/tailscaled.service; enabled; vendor preset: enabled)
     Active: active (running) since Thu 2026-02-19 11:37:54 CET; 179ms ago
       Docs: https://tailscale.com/kb/
   Main PID: 170617 (tailscaled)
      Tasks: 14 (limit: 9331)
     Memory: 63.7M
        CPU: 251ms
     CGroup: /system.slice/tailscaled.service
             ├─170617 /usr/sbin/tailscaled --state=/var/lib/tailscale/tailscaled.state --socket=/run/tai>
             └─170639 dpkg-query --search -- kernel/drivers/net/tun.ko
Feb 19 11:37:54 haedus tailscaled[170617]: logpolicy: using $STATE_DIRECTORY, "/var/lib/tailscale"
Feb 19 11:37:54 haedus tailscaled[170617]: dns: [resolved-ping=yes rc=resolved resolved=file nm=yes nm-r>
Feb 19 11:37:54 haedus tailscaled[170617]: dns: using "systemd-resolved" mode
Feb 19 11:37:54 haedus tailscaled[170617]: creating dns cleanup: route ip+net: no such network interface
Feb 19 11:37:54 haedus tailscaled[170617]: linuxfw: clear iptables: could not get iptables version: exit>
Feb 19 11:37:54 haedus tailscaled[170617]: linuxfw: clear ip6tables: could not get iptables version: exi>
Feb 19 11:37:54 haedus tailscaled[170617]: cleanup: list tables: socket: protocol not supported
Feb 19 11:37:54 haedus tailscaled[170617]: wgengine.NewUserspaceEngine(tun "tailscale0") ...
Feb 19 11:37:54 haedus tailscaled[170617]: Linux kernel version: 6.1.75-axon
Feb 19 11:37:54 haedus tailscaled[170617]: is CONFIG_TUN enabled in your kernel? `modprobe tun` failed
Can someone suggest how do I build these modules for axon? Or can vicharak put it in their headers please?
Thanks :smile: !
I suggest you reload the fresh image the latest one and run those commands again, since we’ve patched many things.
It would be great if you used the Nobel image with the newest 6.1.75-axon Kernel.
1. Download eMMC Image
2. Documentation on how to flash an image in eMMC
3. Update Kernel
