Hi, I had requested to guide on below points:
- How go inside setup and enable to boot from pen drive. As we need to install different
O/S. - Only 1Core of CPU is being used, rest 7 cores are not is use.
Kindly guide and help ASAP.
Thanks
Inder Nath
Thanks
Inder Nath
Also can you send us cpu core dump, of 7 core usages.
Hi @INath,
Hi Team, Thanks for your response, kindly share “new image” for booting with different O/S
Thanks
Inder Nath
Hello @INath,
The SD card image has been prepared for USB boot, and you may download it from the following link: Index of /vicharak-axon/ubuntu.
Please try it out, and feel free to reach out if you encounter any issues.
Best regards,
Pratiksha
@INath few points to consider,
Use this image, build sd card using balena etcher or anything else,
[V1.0_vicharak_axon_5.10_29102024-ubuntu-raw-usbboot.tar.gz]
And then using sd card boot axon and do usb boot,
It has to do with priority of boot interfaces.
