USB C port Display output is not working for axon lite
I have tired connecting usb c to monitor (usb c-usb c ) wire but its not working
Also I have tried with this Protonics Mport
> Blockquote) which works well with Mac & Windows
Micro HDMI works fine
@tallguy , will help you on this.
Will be updating USB C/DP driver on the kernel
Perform the below after tonight 8PM
Done, packages have been updated on the server
perform an update+upgrade cycle as stated above, then reboot
Tell me if it works.
Also could you share the specifics(volts and amp) of your power source for axon lite?
I’m using the 20W iPhone charger, but I think it negotiates power based on what the device needs.
I tested with iphone charge seems display output for the hdmi & usb c is not working
Used 9v Power adapter with 22.5W input HDMI works but not usb c
Logs:
[ 269.712199] usb 1-1.3: new high-speed USB device number 5 using xhci-hcd
[ 269.813500] usb 1-1.3: New USB device found, idVendor=05e3, idProduct=0618, bcdDevice=87.54
[ 269.813560] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 269.813570] usb 1-1.3: Product: USB2.0 Hub
[ 269.878444] hub 1-1.3:1.0: USB hub found
[ 270.172465] usb 1-1.3.1: new high-speed USB device number 6 using xhci-hcd
[ 270.284582] usb 1-1.3.1: New USB device found, idVendor=05e3, idProduct=0752, bcdDevice= 2.33
[ 270.284656] usb 1-1.3.1: New USB device strings: Mfr=3, Product=4, SerialNumber=0
[ 270.284671] usb 1-1.3.1: Product: USB Storage
[ 270.284683] usb 1-1.3.1: Manufacturer: Generic
[ 270.286678] usb-storage 1-1.3.1:1.0: USB Mass Storage device detected
[ 270.287803] scsi host1: usb-storage 1-1.3.1:1.0
[ 270.297171] rockchip-usbdp-phy 2b010000.phy: cmn ana lcpll lock timeout
[ 270.297257] rockchip-usbdp-phy 2b010000.phy: failed to init combophy
This happened on the latest kernel?
Yes I ran the both cmds and updated the system and check
The issue with iPhone charge is due to power can ignore
But with 22.5w usb c seems not working
Also I have installed latest Debian https://downloads.vicharak.in/vicharak-axon-lite/debian/13_trixie/V1.0.1-512-axon-lite-6.1.75-20260912-1210-debian-mate-raw.img.tar.gz
Could you share the dmesg logs when plugging in the c to c displayport cable, and then share the logs for the mport as well, do not filter or grep.
Type in
dmesg -w
Then connect the cable, paste the output here.
Also, could you share the model of the display?
Currently I dont have usb c displayport display , Should the hdmi one work ,where i use mport which has hdmi on it ?
Yes, paste the logs after attaching it
Logs:
[ 1077.701129] PHY_TRACE: register map manual update called
[ 1077.701171] PHY_TRACE: mode change set to true
[ 1077.701184] PHY_TRACE: register map manual update called
[ 1077.701191] PHY_TRACE: mode change set to true
[ 1078.023837] usb 1-1.3: new high-speed USB device number 5 using xhci-hcd
[ 1078.129044] usb 1-1.3: New USB device found, idVendor=05e3, idProduct=0618, bcdDevice=87.54
[ 1078.129134] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1078.129153] usb 1-1.3: Product: USB2.0 Hub
[ 1078.176784] hub 1-1.3:1.0: USB hub found
[ 1078.177107] hub 1-1.3:1.0: 4 ports detected
[ 1078.471879] usb 1-1.3.1: new high-speed USB device number 6 using xhci-hcd
[ 1078.576322] usb 1-1.3.1: New USB device found, idVendor=05e3, idProduct=0752, bcdDevice= 2.33
[ 1078.576402] usb 1-1.3.1: New USB device strings: Mfr=3, Product=4, SerialNumber=0
[ 1078.576415] usb 1-1.3.1: Product: USB Storage
[ 1078.576426] usb 1-1.3.1: Manufacturer: Generic
[ 1078.578645] usb-storage 1-1.3.1:1.0: USB Mass Storage device detected
[ 1078.586538] scsi host1: usb-storage 1-1.3.1:1.0
[ 1078.624229] rockchip-usbdp-phy 2b010000.phy: cmn ana lcpll lock timeout
[ 1078.624331] rockchip-usbdp-phy 2b010000.phy: failed to init combophy
[ 1078.635411] phy phy-2b010000.phy.4: phy poweron failed --> -110
[ 1079.606029] scsi 1:0:0:0: Direct-Access     Generic  STORAGE DEVICE   0233 PQ: 0 ANSI: 0
[ 1079.608919] sd 1:0:0:0: [sda] Media removed, stopped polling
[ 1079.613096] sd 1:0:0:0: [sda] Attached SCSI removable disk
[ 1080.134323] dw-dp 27e40000.dp: test_type0 is not support
[ 1082.474594] dw-dp 27e40000.dp: test_type0 is not support
[ 1082.475260] dw-dp 27e40000.dp: test_type0 is not support
[ 1083.533423] dw-dp 27e40000.dp: test_type0 is not support
[ 1083.534196] dw-dp 27e40000.dp: test_type0 is not support
[ 1085.873513] dw-dp 27e40000.dp: test_type0 is not support
[ 1085.874195] dw-dp 27e40000.dp: test_type0 is not support
[ 1088.213626] dw-dp 27e40000.dp: test_type0 is not support
[ 1088.214411] dw-dp 27e40000.dp: test_type0 is not support
[ 1088.592466] dw-dp 27e40000.dp: test_type0 is not support
[ 1088.593232] dw-dp 27e40000.dp: test_type0 is not support
[ 1098.756725] dw-dp 27e40000.dp: test_type0 is not support
[ 1098.757501] dw-dp 27e40000.dp: test_type0 is not support
I did have one of those portronics devices lying around.
So I did a few tests, applied some tweaks to the drivers as well.
Kernel-deb-package
Install the the deb package using
sudo apt install ./linux-image-6.1.75-axon-lite_20260916-axon-lite_arm64.deb
Also please share if the fix worked on your board. Will help making the experience better for others
I have tested it with mport and its display output is working
Will test with usb c - usb c display output later
Is audio via HDMI or usb c supported ? , as its not working
HDMI Audio does work, it has been tested as well.
Not getting configured could be a userspace issue.
HDMI audio through portronics MPORT would depend on their(portronics) implementation of it, should work with a simple output select on the audio panel.
Audio works , I had to change settings
Can you push the changes as remote updates
Sure, latest patch has been added. You can grab kernel image through apt now!
I checked with Usb c thunderbolt display , It is working and also have check for keyboard and mouse connected to monitor and working via usb c
