I tried using this Sounce USB C to HDMI Adapter since I didn’t have a direct DP cable nor did I have a micro HDMI cable. This adapter works fine on my other devices but seem to cause some power (?) or flicker issue on the axon.
https://www.amazon.in/dp/B0BZSGX9VX?ref=ppx_pop_mob_ap_share
Can you tell us what is the resolution of your monitor?
I tried this on 2 displays
One is a 1080p fhd 60hz the other an old Sony 1080p 30hz TV. Both seem to have the issue.
The issue didn’t occur when I used a direct microhdmi cable instead of a dp adapter.
okay, it seems we have to try with this very adapter and test it, as of now we have tried multiple adapters and all of them worked.
