Vicharak Boot Problem
devashish@devashish:~/Linux_Upgrade_Tool$ sudo ./upgrade_tool ld
List of rockusb connected(1)
DevNo=1 Vid=0x2207,Pid=0x350b,LocationID=32 Mode=Maskrom SerialNo=
devashish@devashish:~/Linux_Upgrade_Tool$ sudo ./upgrade_tool db rk3588_spl_loader_v1.14.113.bin
Download boot ok.
devashish@devashish:~/Linux_Upgrade_Tool$ sudo ./upgrade_tool wl 0 V2.0.0_vicharak_axon_6.1_22092025-ubuntu-noble-24.04-raw.img
Start to write V2.0.0_vicharak_axon_6.1_22092025-ubuntu-noble-24.04-raw.img at 0x0…
Write LBA failed!
Could you try with turn off the axon and plug it again power cable and do same process again!?
And Also tell me the size of image.
Tried turning off the axon and power cable and did the process but still same result. The size of the image is 6.6Gb
I hope you using x86 system to flash.
I am using Linux ( Ubuntu 24.04 ) with Architecture: x86_64
Now, There should be some issue,
Try with eMMC image as well.
  1. Put Axon into Maskrom mode.
  2. Then flash image using sudo upgrade_tool uf <image>
Now there is a different error
devashish@devashish:~/Linux_Upgrade_Tool$ sudo ./upgrade_tool uf V1.0_vicharak_axon-6.1-04032025-ubuntu-noble-emmc.img
Loading firmware…
Support Type:3588 FW Ver:1.0.00 FW Time:2025-03-04 12:46:33
Loader ver:1.0b Loader Time:2025-03-03 10:38:52
Start to upgrade firmware…
Download Boot Start
Download Boot Success
Wait For Maskrom Start
Wait For Maskrom Success
Test Device Start
Test Device Success
Check Chip Start
Check Chip Success
Get FlashInfo Start
Get FlashInfo Success
Prepare IDB Start
Prepare IDB Fail
Note:please check flash if in the support list or welding issue
