I am making a project of object detection using 02 camera. I have prepared the model and tested it using raspberry Pi camera 2 and axon sbc. Now i have to deploy the project. The camera needs to be water proof and cable length approx 10m. Can someone suggest how to do it.
I think the enclosure has to be designed in that way, but I am little bit concerned about the 10m cable length for the camera! If you are using MIPI cameras like raspberry pi camera 2, the length will not exceed more than few centimeters.
You can use USB 2.0 or IP cameras for the better result, then you can get video feed from much farther way.
