ERROR: libxcrypt-4.4.33-r0 do_configure: configure failed
ERROR: libxcrypt-4.4.33-r0 do_configure: ExecutionError(‘/home/yocto/yocto-vaman/build/tmp-glibc/work/armv8a-oe-linux/libxcrypt/4.4.33-r0/temp/run.do_configure.93346’, 1, None, None)
ERROR: Logfile of failure stored in: /home/yocto/yocto-vaman/build/tmp-glibc/work/armv8a-oe-linux/libxcrypt/4.4.33-r0/temp/log.do_configure.93346
building yockto image for rk3399
It resolved, will update today.
@firmware02
Before building Yocto image, run command below:
source oe-init-build-env
devtool upgrade libxcrypt 4.4.38
hello
I am working with the Vaaman RK3399 board and would like to request an official bootable SD card image compatible with this platform.
Kindly provide the appropriate image file, along with any necessary instructions or tools required to flash and boot the board successfully.
Board Vaaman -RK3399
Requirement - Bootable SD card image
@firmware02, Working on it.
