Wi-Fi AP Stability Issues with Multiple Clients
We are experiencing Wi-Fi Access Point stability issues on the Vicharak Axon when multiple Wi-Fi clients are connected simultaneously.
Observed Behaviour:
  • Clients initially connect to the AP successfully.
  • Frequent and unexpected disconnections occur when multiple clients are connected.
  • Disconnected clients repeatedly attempt to reconnect.
  • Maintaining stable connectivity across multiple clients is difficult.
Expected Behaviour:
The AP should maintain stable connections with multiple simultaneously connected clients without unexpected disconnections.
Points Requiring Investigation:
  1. AP stability under multiple concurrent client connections.
  2. Wi-Fi driver and firmware stability.
  3. Maximum supported simultaneous client capacity.
  4. AP configuration or hardware resource limitations.
Could the Vicharak team help us identify the root cause and suggest possible fixes to improve Wi-Fi AP stability?
Okay, will look into it.
Make sure antenna is connected on correct port.
