Yep, I did try to preview the applied changes, but it didn’t show anything
Okay, give me some time, will resolve it within an hour.
You can see which theme will be applied by below command
ls -l /etc/alternatives/*.plymouth
What I suggest, first remove your custom theme and text theme which is default for minimal image.
sudo rm -r /etc/alternatives/<custome>.plymouth
sudo rm -f /etc/alternatives/text.plymouth
Apply other themes
sudo apt search plymouth
sudo apt -y install plymouth-theme-sabily plymouth-theme-hamara plymouth-theme-spinner plymouth-x11
I suggest you can apply below theme and edit in it as it gives you more functionality.
Animated plymouth theme
vicharak@vicharak:~$ sudo update-alternatives --config default.plymouth
There are 5 choices for the alternative default.plymouth
(providing /usr/share/plymouth/themes/default.plymouth).
Selection Path Priority Status
* 0 /usr/share/plymouth/themes/bgrt/bgrt.plymouth 110 auto mode
1 /usr/share/plymouth/themes/sample/sample.plymouth 100 manual mode
2 /usr/share/plymouth/themes/bgrt/bgrt.plymouth 110 manual mode
3 /usr/share/plymouth/themes/sabily/sabily.plymouth 60 manual mode
4 /usr/share/plymouth/themes/test/test.plymouth 100 manual mode
5 /usr/share/plymouth/themes/vortex-ubuntu/vortex-ubuntu.plymouth 100 manual mode Press <enter> to keep the current choice[*], or type selection number:
- Select bgrt.plymouth auto mode
sudo update-initramfs -u
In order to apply your custom theme,
You may need to run one more command
update-alternatives --install /usr/share/plymouth/themes/default.plymouth default.plymouth /usr/share/plymouth/themes/mytheme/mytheme.plymouth 100
We are currently facing an issue with our webapp on the Vicharak boards:
- The app works fine on other browsers, but on the boards, Chromium (v91.0.4472.164) does not render TailwindCSS styles correctly.
- This is because the deployed webapp relies on modern CSS features (e.g.,
oklch(), container queries, etc.) that are not supported in Chromium 91.
To resolve this, we need to update Chromium on the boards to a more recent stable release (ideally v110+). Could you please help with updating it to the latest stable version supported for our architecture.
This update is critical for proper rendering of the UI. Please prioritize and let us know once it’s completed.
Okay, noted your issue, working on it.
@pawarvarun, Run Below Script to setup kiosk with newer version of chromium 114.
kiosk-setup-chromium.sh (1.9 KB)
Thanks man, it’s working!
